Revit MEP Forum
Adding an angle parameter to family
2 REPLIES 2
eriktoom
1399 Views, 2 Replies
I would like to add an angle parameter to my object but I cannot figure it out how to achieve it. Please see the pictures below. Right now I have to rotate each element manually (see Collar 1). The end result after the rotation is shown in Collar 2. Instead of rotating each element manually I would like to select certain selection of elements and apply the angle to them.
I have inserted the .rfa file as well.
2 REPLIES 2
PavelAnd
in reply to: eriktoom
Hi @eriktoom ! Hope I understood the task correctly... The elements around the pipe must be nested families. Then you can create an angle parameter and assign it to them. See new family below. 
Best regards, Pavel Plotitsyn.
eriktoom
Great work! That is what I wanted to achieve!
Forma Design Contest
Technology Administrators
