I would like to add an angle parameter to my object but I cannot figure it out how to achieve it. Please see the pictures below. Right now I have to rotate each element manually (see Collar 1). The end result after the rotation is shown in Collar 2. Instead of rotating each element manually I would like to select certain selection of elements and apply the angle to them.
I have inserted the .rfa file as well.
Solved by PavelAnd. Go to Solution.
