Yes/No Null Value Equivalent to No in Conditional Statement
A huge problem with using a Yes/No boolean parameter in a conditional statement as a calculated value in a project is that null values do not get evaluated as NOT meeting the Yes condition. Therefore, when I have a Yes/No being evalutated in a conditional statement, such as whether or not a Yes/No parameter is checked to determine which room number to report for a door, each checkbox must be explicitly set to checked or unchecked. In the example of the door room number, as doors are added, they default to a null value, and the formula of the conditional statement doesn't treat the null as No when I want the conditional statement to only be true if the checkbox is explicitly checked.
9 Comments
Another option would be acknowledging NULL as a condition in a conditional statement. Where 0=0 is true, and 0=1 is false, have something similar to represent null.
dplumb_BWBR
I agree this is a bug and needs to be fixed.
In the meantime, what we've done as a workaround is to use double negatives.
Rather than using
Parameter equals Yes
we use
Parameter does not equal No
That gets you around the "isn't set" value
pieter7
senglychau
I've tried to use the double negatives in Revit Formula, the double "not" doesn't cut it.
dplumb_BWBR
Maybe I should have included an image.
By "double negative", I did not mean (not (not
As I said, we use
As in the first filter below
senglychau
Thanks, that is a great workaround and Autodesk still need to add the equivalent "does not equal to" to Revit Formula, Conditional Operator. As mentioned, not(not(-)) is not the same
j0258169
I would like to be able to run a calculated value on a sheet list Yes/No parameter that has not been checked/unchecked, but is null (the default greyed out check). I understand that this value is not Yes and is not No. But I would like to be able to calculate them as Not(Yes) or Not(No), because null would in fact fit both of those statements.
pieter7
We often only want to schedule elements that have a value for Mark or Type Mark. The problem now is, that a filter that says
Mark does not equal 'empty field' does not really work. Because it looks for 'null' but NOT for empty fields (a field that once had a value but has now been deleted). This is very confusing for most people.
Geoffrey.Jennings
A suggestion could be to use the same methodology of assigning 'Parameter Default Value' as occurs when you add a shared parameter to a project and assign the parameter to the 'Material' category.  This way each new element would have the default value of 'No' and be unchecked by default.
