Show only
Search instead for
I hope you're talking about length, width and height / depth parameters. Because X,Y,Z are just cartesian coordinates. And those parameters have constant values only for the simplest shapes (3D primitives). For complex shapes , like conceptual masses, all parameters are variables defined by some functions. Displays functions might be useful too.
Revit has too little engineering (maths) aproach.
We also need Level dimensions in schedules. To easily see Base level and Top level of walls, beams, columns, etc.
I understand your wish, had the same problem. We are used to coordinates like in AutoCAD or others applications and working in projects, which where georeferenced.
As far I understand the logic of Revit, you must look at your model itself viewed locally. You can define a georeference point, but the software doesn't work with the georefenced system. If you want coordinate lists for the execution of your construction, I recomend you to create a point family and write a Dynamo Skript to it. From there you can create the X, Y, Z parameters and file them in the model, and further export the data to excel.
The Skript is a easy math, vector geometry: transforming the vectors on the local reference to the georefenrence ( rotate + move)
