workset organization
Hello Autodesk Team
please add a feature in workset dialog for an organization workset created.
for example, Add Folder and Sub-Folder for created workset for control worksets.
12 Comments
CFNBen
Worksets are not layers, stop treating them as such.
Autodesk please do not take any notice of this idea.
Thierry.A
I agrée with benmcqueen
dplumb_BWBR
I third the comment.
In your example, you have I-WALLS and E-WALLS (hmm wonder where that came from?)
Revit already has a Wall Function parameter for Walls that can be set to Interior, Exterior, Foundation, Retaining, etc.
You can use that parameter to set up filters instead of Worksets
GHASEM_ARIYANI
HELLO @dplumb_BWBR  @Thierry.A  @CFNBen
Thanks for your good posts
Hello
I know this was just an idea for better control and categorization (of course I think). 😁
BarrieSharp
I would encourage the use of categories to organise your model.  Maybe beyond that use filters with element data.  The main principle of BIM is that the elements know what they are and organisation can be based on queries rather than hierarchy like any other database.
Worksets are meant to assist with allowing multiple users to work on the same model.  User worksets are largely legacy since borrowing was introduced.  However, they can still be a powerful tool when used appropriately and help to break a large model up for performance.
It looks to me that this suggestion is born of a misappropriation of worksets and I recommend starting here Revit OpEd - How Many Worksets Do I Need? to review best practice.
Zwielehner
Hi @GHASEM_ARIYANI
If you do need many workset and you are tired of switching between them all so often, consider this little tool that switches between preset worksets automatically (by category, family or type):
https://apps.autodesk.com/RVT/en/Detail/Index?id=6384070377181495514&appLang=en&os=Win64
(disclaimer: I'm the developer and I'm more than happy to make further improvements to this!)
gmurphy
It would be very useful to have new functionality in the Worksets dialog which allows teams to group worksets. That way you would be able to load/unload worksets in bulk very quickly if each group had its own checkbox.
Tim_Askelson
It would be helpful to have a function of being able to move Worksets into a folder structure within the Worksets dialogue box, so for example, if you had multiple buildings in a single Revit model and weren't going to be breaking them out and linking them back in, you could prefix Worksets with building acronyms, and then move them into appropriate folders and control visibility further, and set them not to show on model open for improved processing and functionality.
mcarreraC4W4B
Observer
GOOD IDEA.
mcarreraC4W4B
Observer
Tim, that is a good idea, perhaps the capability to select a few worksets into a group.
Martin_Chan3BX85
How about making a user profile for the opening worksets?  I tired to select the worksets everytime opening revit.
baby_kutty
MUST HAVE FEATURE 👍👍👍
