Wall Join with Reference plane in PLAN
Why we are not able to cut  a wall to change its end to 45 degrees on plan view.
I've tried Cut Geometry/Join / attach with a Reference plane but that doesn't work as it works only in Elevation view.
" The Reason for this purpose for example that the perpendicular wall exist in another linked file "
p.s. I know a workaround by using  Model in place > Solid void > Extrusion > Make a rectangle > Extrusion properties > Extrusion end: same height of wall > Finish extrusion > Select the void > Rotate it 45 degrees as needed, and/or stretch it as needed. > Modify > Cut geometry > select the wall, then select the void > Finish model in place.
BUT ,we really need it in a direct way without a workaround.
1 Comment
opesch_
We've used 2 way in a big project in 2011 where no wall had perpendicular ends
(without using the cursed inplace voids) :
  • vertical wall reveals
  • doors of the same height as the wall
a two level based GM family would now also do the job in even a BIMer way ! 🙂
