Void/Hole in stairs and landings
Would be nice if a shaft or void could cut through stairs and landings or if you could edit the profile of a landing and draw some inner boundary lines to create a hole.
Example is a landing which needs an opening around an existing column.
3 Comments
Keith_Wilkinson
Riya.ghoshE9ZJD
Autodesk Support
It is not possible to cut through a system stair landing, even with voids. This is a common requirement & would be good to have this feature in Revit. There are multiple suggested workarounds in the forum post below, but these methods are very time-consuming & working with line weights is not a very convenient option.
Forum: https://forums.autodesk.com/t5/revit-structure-forum/create-opening-in-staircase-landing/m-p/7134462...
wr.marshall
If for what ever reason this should be allowed in the run too. Would make easier modeling where you have a central column on a circular staircase cutting the treads.
