Similar to carpentry work, elements of foodserviceequipment should also be visible if they are located above the cut plane.
Otherwise, elements such as wall shelves and wall cabinets are not visible. It would also be desirable if elements above the cut plane could be displayed differently in the plans, as could elements that are hidden within the cut plane.
Currently, these two different situations cannot be displayed differently based on the view area. If the line style “Outside the area” is changed to dotted, for example, hidden elements and elements above the cut plane are displayed in the same way.
this ends up that the way of displaying the element needs to be modeled with specifc subcategories like "Overcounter" that their appearance can be controlled differnt to other elements.
In fact this workaround is bugy because the same elements sometimes are placed under the counter, somtimes on the counter and sometimes above the counter like for example a micorwave. This fact results that the appearnce of the same element ends up in incorrect appearance.
