Viewport settings
Viewport settings
Awkward - when a view is placed on a sheet, it's suddenly called a viewport. And it suddenly has a type. Smells a bit like AutoCAD. Anyway, what I would like is to set the view'port' type _before_ I place it on a sheet. I.e. when a view is opened, the Properties Panel should display something like a drop-down to set the type of view'port'. Just like it has, for example, for Display Model.
1 Comment
K-Eastman
To add to this request, it would be beneficial to be able to assign a viewport type to a view in the view template so the proper view titles are associated with the correct views. We use a modified view title with a north arrow for plans and it would be less time consuming if I could assign that viewport to the views so they automatically have the right view title when placed on the sheet.
