Viewport settings
Awkward - when a view is placed on a sheet, it's suddenly called a viewport. And it suddenly has a type. Smells a bit like AutoCAD. Anyway, what I would like is to set the view'port' type _before_ I place it on a sheet. I.e. when a view is opened, the Properties Panel should display something like a drop-down to set the type of view'port'. Just like it has, for example, for Display Model.
Comentarios
To add to this request, it would be beneficial to be able to assign a viewport type to a view in the view template so the proper view titles are associated with the correct views. We use a modified view title with a north arrow for plans and it would be less time consuming if I could assign that viewport to the views so they automatically have the right view title when placed on the sheet.
