View Title Extension Line: Length based on Title Length
Is it possible to have an option to constrain the Extension Line of a View Title based on the title length?
It would be have a fixed extension from the end of the text, like shown in the image below, and being able to set this space to achieve consistent extension lines
Thanks and Kind Regards
6 Comments
krrp
It can be done by editing the view title. Change the label text to contain underlined text. You will have to select the detail number text as well and duplicate it with a different name then deselect the underline for the detail number text. Save it all for future use in your template and load into project. When back into the project or template, select the view title again an uncheck the extension line box.
thank you,
We explored this possibility but it has been deemed as not acceptable from a Graphic Standard point of view, hence the request...
yavork
It will be even better if we can also choose the direction of the default extension line (Left/Right)
(We also dismissed the underline text as option.)
Click on the view and it will highlight the title. On the end of the line you will now see a blue circle, you can now drag that to the required length.Revit title.JPG.
cslatteryAXGRE
There should be a way to give the line under the view title a distance instead of just stretching it. That way they can all be the same.
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
 The Factory
