Make it possible to use a View Template within a View Template.
For me working in a MEP Engineering Company we use al lot of Templates with just a small difference.
It would be great for example if you can make a Filter Template with can be added to a lot of existing View Templates. The filtering within the Templates is for 60-80% the same, systems are colored etc.. Now you have to copy paste them, that's ok ...
BUT if you want to change, you have to change them all 😞
I think, just a simple check box can do the trick, choose to use the default filter or use a Template...,
The same for default View Ranges etc... Just think and you see the opportunities :-),
(maybe even using more than one View Template, easier to build within Revit?)
