Vertical Schedule Orientation
Be able to toggle from a horizontal oriented schedule (elements in rows, parameters in columns) to a vertical schedule (Parameters in rows, elements in columns). Currently Revit only supports a horizontal schedule.
This would allow more flexibility for what can be fit on a sheet. Vertical schedules especially makes sense for scheduling a few elements that have many parameters you need to schedule.
81 Comments
mariano_perez
Hard to understand why this is still not a feature...
wr.marshall
found this on AUGI from back in 2010 - The ability to create horizontal rather than vertical schedules (augi.com)
Does Autodesk even look at AUGI wishes anymore now that they stopped the ability to add new wishes?
The original idea here was first posted in 2017, so 7 releases since starting Revit 2019 in 2018 and still nothing. Is annoying when simple ideas like this are ignored which are required by so many, but Autodesk add niche features like elliptical walls as seen in Revit 2020, which will hardly ever be used  as most designs will be rectangular in nature.
amartinezDCENV
I support this!
Dr_P_akbari
I support this!
amplogho
I also need this. It seems like it would be really easy to add this option and I have so much information that needs to be presented in this format that I am forced to import from excel because Revit can't do it natively.
tiffany_tanBJ73G
I support this!
lumega
I support this aswell.
abaroja
I support this
jake_parker4ZKCY
Make this a reality please, its ridiculous this still isnt a feature. It is almost there already, the schedule can be flipped on the sheet, just make the values horizontal on the sheet!
jaylistoe79PAT
Community Visitor
Please add this feature! So necessary!!!!
ankit.kYHRHK
Autodesk, are you listening ??
revitebim
Eu apoio isso plenamente! Extremamente útil para Elétrica e Dados.
Em projeto de Dados tenho mais de 200 pontos, em que os cabos  RJ45 que tem que ser calculados em Colunas, porém depois é necessário transpor as colunas por linhas.
alanyRQN83
We're now on to Revit 2025 and I also strongly support this. Many Architecture practices schedule Windows/Doors in such a way that having parameter titles as the left-most column with parameter values to the right is much more efficient on a sheet.
vs
kemebradikumo_prenegha
Community Visitor
I will prefer and option of updating revision schedule from left to right just as we have Top to Bottom and bottom and Bottom to Top. This will provide verity of option to either leave the revision at the bottom of the sheet  or at the right side of the sheet.
when there are other notes  or description to be added at the right side of the sheet there will not be enough space to include the schedule on the right side, however some contractors prefer their drawings and revision to be at the bottom moving from left to right.
Ric_Weber
@kemebradikumo_prenegha, it doesn't appear that you have voted for this idea, even though I believe what you are asking for would be solved by this solution.  Perhaps I'm just not following what it is you want.  You can put your fields in any order you want, so I'm not understanding your desire here.  Perhaps an image of how you would want to see the revision schedule might help.  Do it up in Excel or something to look how you want and then take a screenshot or snip of that and post that.  Perhaps yours needs to be a separate idea, perhaps not.  I'm really curious as to what you are looking for.
fegerer
Observer
Please add this.
lpendergraft
Please include this as soon as possible.
e_umbert
Observer
We would need this for our projects. Do, please, implement this feature in the next version.
theRicWeber
e_umbert
Observer
Please do implement this function
