User interface - Ribbon Customization
To be able to personalize the order of the Ribbon tools
And/or to be able to have more than 1 row of ribbons below each other (optional)
6 Comments
wr.marshall
The ability to create custom user ribbons and add functions required for that ribbon.  That way I could add functions  together, which make sense to me, even though they might not make sense to the next person. or my own commonly used functions... thus mixing and matching functions from default ribbons like a wall from architecture, align from modify, toposurface from site... And I could then call this "Architecture 2", well the next person might call this "construction"....
The rule part of the idea is that if I clicked on Roof it would create a temporary Roof Ribbon, which would show all tools for various types of roofs and anything I felt was a roof related tool like creating a take-off schedule.
. ie Starting the roof tool would show a ribbon specially for various roof types like foot print, Extrusion, by face, soffits, Fascia, Gutter... If I ended the roof tool this ribbon would disappear . This would be similar to the hatch ribbon in AutoCAD. When the hatch feature is not visible, you cannot see hatch options, unless you select a hatch or start a hatch action.
Tags (5)
fruity101079
Hi
We can hide discipline tabs we don't use, but we can't customize buttons.
There are some buttons i will never use and they are poorly placed, i often click on them. So i would like to hide them, or move them.
MiWolff
I found no way to rearrange the commands inside the ribbon. There is the quick access bar that you can make use of, but why not allow to move entries from any given ribbon tab to wherever it deems appropriate to user? Well that is the idea: Allow moving commands wherever.
olivierbayle4523
Hi team,
I’d like to propose a new feature for Revit aimed at improving user productivity and workflow efficiency.
Proposed Enhancement
Introduce a fully customizable tab within the Revit interface, where users can group and access their most frequently used commands.
Concept Overview
This tab would function as a personalized workspace, allowing users to:
  • Add, remove, and organize commands based on their needs
  • Group tools by workflow, discipline, or task type
  • Access frequently used features without navigating multiple ribbons or panels
Rationale
While Revit’s ribbon is powerful, it can become complex and time-consuming to navigate, especially for advanced users or cross-disciplinary workflows.
This feature would:
  • Reduce friction in daily operations by minimizing navigation time
  • Adapt to user profiles (architects, structural engineers, MEP, BIM managers, etc.)
  • Support power users who rely on a subset of tools repeatedly
  • Improve onboarding by allowing simplified, task-oriented interfaces
Potential Features
  • Drag-and-drop interface to add commands to the custom tab
  • Ability to create multiple custom panels within the tab
  • Save/load configurations (user profiles or company standards)
  • Optional sharing of configurations across teams
  • Compatibility with existing shortcuts and add-ins
Regards
Olivier
Expected Impact
This would bring Revit closer to a user-centric interface paradigm, similar to customizable toolbars seen in other professional software, while preserving the depth of its existing functionality.
Tags (1)
Ric_Weber
@olivierbayle4523, this is an excellent idea and extremely well worded and thought out.  However, please remember to search for existing ideas before posting new ones.  I find that "speak like caveman" works best... i.e. in this case, "ribbon custom", brought up https://forums.autodesk.com/t5/revit-ideas/user-interface-ribbon-customization/idi-p/10413829 as the very first item.
@kimberly_fuhrman-jones, could you please add this wonderfully well written item over to the more succinct idea I linked above.
I would add to this excellent idea a few key points:
  1. This could replace the QAT all together if it could be sure to work with add-in's tabs and tools as well.
  2. Ability to save different "profiles" that a user could switch between as they rotate between tasks and duties during the day.
  3. Just like now, the ability to save/export/import these profiles for portability.
  4. Include the keyboard shortcuts as part of this exportable file and profile set-up for simplicity.  Heck, just include everything in the Options as a single package, make life more simple for us all.
  5. And I hate to say it... "just like AutoCAD" 'ACK'... give us a "migrate from previous release" tool
Note to the developers: the main idea is more important than these little add-ons that I've piggybacked on here, so work on the main idea first!
Ric_Weber
I just thought in re-reading my points in the previous comment...  Just make the QAT look like a ribbon tab (or just more ribbon like(?)) and at the same time, give us options for more than one QAT that we could switch between.  Let us easily hide any of the main ribbon tabs so we can hide those that we almost never use, but will need occasionally.  I think that would solve all of this.
