Revit should have an option to suppress or bypass error messages during model opening. I just opened a major project model and it took quite a while to load and download and every few minutes it stopped to throw about six errors from the following causes:
1. This project needs a coordination review
2. A link is broken to a rvt or dwg
3. Do you want us to pull from paperspace in the linked DWG? (screenshot attached)
etc.
These all should be warnings or errors that can be fixed inside of Revit. These should NOT stop a load. Go ahead, do the load and then report the problems and let people fix them if they want.
Admittedly these errors are caused by sloppy use of BIM, but eliminating that is hard so I respectfully request this change. 🙂
