unlock all facade elements of a wall at once
When editing facades you (sometimes) need to unlock a good deal of panels that need to be altered. How unlocking them all in one go? Maybe double clicking the unpin icon could give users a coloured frame around the current view to show that the element in question is no longer protected. Another double click would return to the normal locked state or keep those that were changed unlocked.
1 Comment
samuelsanf
Hi @MiWolff ,
For curtain wall you can right click on it -> selected panles/mullions -> Panels/Mullions on Host to select all and then unpin all at the same time. You also can do the same with more than one curtain wall selected.
There is also option to select all panels on a specific vertical or horizontal axis if you right click on panel.
For mullion you have the same options, plus some more, see here:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2023/ENU/Revit-G...
