UNDO SELECTION BOX
UNDO SELECTION BOX
I request that we have the ability to toggle a selection box on/off with a customized keyboard shortcut. Right now, you can type BX to get a selection box around highlighted items, but in order to undo it, you have to deselect and uncheck in the properties tab instead of just being able to type BX (or something else) to go back to the full 3D view. Thank you!
5 Comments
mike
Maybe "XBX" to turn it off.
UNDO or UNCHECK SECTION BOX BY USING CUSTOME SHORTCUT
Hello guys,
I also have the same trouble with the comment above,
When I tried to customize my own shortcut, that was not available for UNCHECK - SECTION BOX,
Can anyone helps us, It will really help users to faster in modeling
Best regards
Thank you so much
@ToanDN @Alfredo_Medina @constantin.stroescu
WSpierMDSK
Just go to the Properties menu and under the Extents section, there's a check box by the Selection Box option. Uncheck the Selection Box.
DanielRosenberg
Awesome idea!  Please also fix discrepancy that the ribbon calls it a Selection Box and the Properties Box calls it a Section Box.
nicholasPM7CG
Can Autodesk please put ALL commands and functions etc in the shortcuts list like in Autocad please?
