true measurement isometric
When a 3D isometric view is printed, it cannot be measured properly with a scale. therefore it cannot be used as a construction document. Revit already has perspective views. 3D views have scale factors and therefore should be true measurement regardless of whatever angle is chosen. IF you dont plan on fixing this then you should take away the scale option for 3D views in general since it does not make a difference
