Revit allows users to insert schedules from other Revit models and reuse their schedule setup and formatting.
However, this workflow is limited when the source model is a Revit Cloud Model hosted on Autodesk Construction Cloud and the source model is not open.
I would like to propose the ability to select a Revit Cloud Model and transfer a schedule to the current model without opening the source model.
The transferred schedule should preserve its complete configuration, including fields, filters, sorting, grouping, formatting, calculated values, headers, footers, conditional formatting, schedule appearance, and Filter by Sheet settings.
For example, a company may have a standard Cloud Model containing approved schedules with predefined company standards. Users should be able to select this model, select a schedule, and transfer the complete schedule configuration into the current project.
The proposed workflow would be:
Select Cloud Model
Select Schedule
Transfer Schedule Configuration
Use the Schedule in the Current Model
This would be especially useful for BIM teams managing multiple projects on Autodesk Construction Cloud.
The goal is to transfer not only the schedule data, but also the complete schedule definition and formatting so that it can be reused as a BIM standard.
This feature would reduce repetitive setup work and make schedule management across Revit Cloud projects much more consistent and efficient.
