Trace-Heating and more Options for Pipe-Insulation Tables and Color
For Pipes in Cold Areas, often a Pipe-Insulation is not enough to Prevent a Pipe-Burst due to Water freezing.
Here Trace-Heating Comes as a Solution. An Electrical Heating cable wired around the Pipe. An Option in Revit to
provide These cables and the Cable-Parameters like Length, Size, Watt per Meter per Temperature, and Maximal Watt/Meter, Total Wattage consumption at Zone/Mep-Room temperature. Also the Cable around the Pipe should be displayable. The Options for the Insulation should also Extended, with a Table for Insulation-Thickness per Pipe-Size --> Not all Insulation Thicknesses exists for all Pipe-Sizes. Give us the Option to Limit the allowed Thicknesses. Also The Color of the different Insulation-Families should be different to easier Show the Type of Insulation which is used. Some insulation are flammable and some are not. (See attached picure for more Information)
3 Comments
Mark.Friis
There should also be the Option to automate the pipe insulation-families, and make them dependent on different Parameters like Zone-Temperature, Zone-Fire-protection-level, Wall-fire-protection-level (at Wall or floor openings), Pipe-size, Pipe-System-type, Pipe-Type, Pipe-material, Pipe-Flameabillity-Level, Opening size, and etc.  + the Option to add further Parameter dependenzies. So when you draw a Pipe, it will automatically add the Right Insulation-typ in the Right thickness at the Right place. Doing this manually is about 1/6 of the total time it takes to draw a pipe-network. And 1/2 of the time it takes to make the Pipe-finish after a recalculation (Resizing the pipe-size and the Insulation). Btw. pipe-resizing is an Option under the Calculation-Header, insulation should also be.
Mark.Friis
Also the when drawing the Pipe, directly type in the insulation thickness, instead of adding it afterwards.
trout9F56M
Also need to be able to put more than 360000" of insulation on a pipe.
