I have been trying to override the topography in specific views of the project, but unfortunately, there is no way to control its colour using rule filter, selection filter, object styles, overrides. Apparently the only way is changing the material, which affects the entire model, including linked Revit files. This is a significant limitation of Revit.
The same issue occurs with stacked walls. While Revit allows walls to be stacked, it is frustrating that I cannot apply filters, such as the fire rating rule, in a plan view. What is the point of having stacked walls if we can't use these essential features?
Please update this in the coming Revit versions.
Best,
Alex
