TAG - curtain wall mullion
The curain wall mullions can't be tagged (I don't want to use a workaround with materials or keynotes).
17 Comments
Purus_Cdds
Do you have any sample tagging to share with me?
ALECARDOSO2016
Não dá pra usar tag de material quando se quer classificar os montantes por tipo e comprimento.
Quando teremos realmente identificadores de montantes disponíveis para utilizar?
[You can not use material tag when you want to sort the mullions by type and length.
When will we actually have identifiers of mullions available to use?]
This capability would be especially helpful for heavily-customized curtain walls (multiple cap profiles, depths, mounted accessories, etc.).
ALECARDOSO2016
No sense this functionality is not available !!
It takes a lot of work, besides being very inaccurate, to use another tool for this purpose.
When will we have mullion's tags?
please create curtain wall mullion tags! The world love glass. Curtain walls are becoming more complex, and if not, definitely more widely used. Being able to tag would help the the entire glazing industry and push those who aren't already to use Revit!
jeanmarc.couffin
89 votes is not enough? the previous archived idea got 10 votes.
Please do add that small thing to your roadmap. @sasha.crotty
thanks
Nurlan-A.
Why still "gathering support"? This is the necessary functionality.
Here is a workaround that transfer instance parameters of the million in a keynote value via Dynamo
https://youtu.be/l4ScFNEz8ec
almeidaandre
Does Revit 2021 fix this?
Autodesk Mar 13 2019 - how difficult is it to open the Tag API to curtain wall mullions or any other elements when they are already available n schedules?
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
E.Pijffers
Great news! 🙂
We are pleased to say that this has been implemented in Revit 2022!
-The Factory
Tarek_K
Status changed to: Gathering Support
jeanmarc.couffin
@Tarek_K you don't want to archive instead?
@jeanmarc.couffin
There is an issue with the forums. The Implemented status vanished from several boards. We are working with support to get them restored.
-Kimberly
Tarek_K
