Sync All Open Projects
I have a multifamily project - have multiple unit types open as projects (to avoid the fix groups errors).  I'd like to be able to sync all with a command instead of going to each project individually and sync each.
13 Comments
marko.Zeljkovic
Yes yes yes!
marko.Zeljkovic
Not sure why my vote is not counted?
Zanyar.K
If we get such a function, the work will be much easier with many projects at the same time, which I often have.
jake.andersonRLLLW
Community Visitor
That would be very helpful
Amy.Sutton
Observer
Even better, sync and close all open projects - so you don't have to sit waiting for each open file to sync and close, sync and close, sync and close...
ChrisGamble
I want to be able to sync all open models the same way CAD can save all. seems simple enough, revit already has the ability to do things that effect all open models in a session, such as loading families. Why not sync all? In multifamily I work across a lot of models at once, having this ability increases speed and decreases effort greatly.
Marcus.Isacsson
Revit idea: I would love being able to batch sync all open files.
Currently I'm working in a larger project where we're having eight files at the moment, and it's quite common that all of them are opened (plotting etc.). Would be neat to sync them all with less clicks.
Tags (5)
matthewsXACAN
To Amy's point, it would be incredibly useful to open multiple files without having to open one at a time.
Ziyao.li
6 years later, would any autodesk staff response?
bryceUT3KU
ditto
ndagostinoAC229
Community Visitor
this would be helpful, as sometimes there are several projects i'm working on at the same time
it's been 7 years and here we are
marko.Zeljkovic
nowadays I keep every model open in its own revit instance. so this command should be available for all revit instances, simultaneously.
