Switch Phases - Balanced Load - BUG
A friend found this strange behavior on the Schedule Panel when using Switch Phases on Revit 2021 and 2022.
When you switch phases on an electrical circuit with 2 hot wires and the circuit has a balanced load, for some reason,
Revit unbalance the load circuit and consequently add a Neutral wire even if the Wire Type has Neutral Required disabled.
This just happens on the phases AC and BC, if the circuit is on the phases AB works like should be.
I hope this helps to improve the next version of Revit.
Related Links:
2 Comments
Status changed to: Accepted
We think this is a great Idea, so we've decided to add it to our roadmap. Thank you for pointing this out!
The Factory
ricaun
Hello
This bug was fixed in Revit 2023
Unfortunately, https://forums.autodesk.com/t5/revit-ideas/wire-size-neutral-bug/idi-p/10784398 this still bugs me!
