Surface Fix
Surface Fix
I am an Interior Designer/Architect and I use The Surface Book by Microsoft. Your Software is amazing and for class projects it totally rocks. While there are already slight fixes to getting the soft ware to work well on the SurfaceBook I think you guys should look into be able to make Revit work Seamlessly on higher scales such as a 200% scale.
3 Comments
sasha.crotty
Marking as implemented. High-DPI support is available starting with the 2017.1 release. Thanks for submitting your idea!
Tarek_K
Status changed to: Gathering Support
Tarek_K
