According to the 2011 NEC 517.73(2), the demand factor for x-ray equipment is based on the number of pieces of diagnostic equipment on the panel. While most demand factors like this work with the way Revit is set up, the demand factor for X-ray equipment does not. For X-ray equipment, the demand factor is either:
- 100% - if there's only one piece of equipment
or, if there is more than one piece of equipment:
- 50% of the first piece
- 25% of the second piece
- 10% of any remaining pieces of equipment
For example, if I have four pieces of equipment, one fed from 1HA, one from 2HA, and two from 3HA, with all of these panels fed from MSA, demand factors at the panel would need to be calculated as follows:
- 1HA - 100% of the equipment rating
- 2HA - 100% of the equipment rating
- 3HA - 50% of the largest equipment, 25% of the next largest equipment rating
- MSA - 50% of the largest equipment (among all 3 panels), 25% of the next largest equipment (among all three panels), 10% of the remaining equipment ratings
With the way Revit supports demand factors, we either have to apply a demand factor of 100% for the first piece of equipment all the way to the top of our system (i.e. MSA), or we don't comply with the NEC in the event that there's only one piece of equipment on the panel. While it is nice to use Revit to design our power distribution, there are quite a few things missing such as this which prevent us from being able to really take advantage of it.
