Super multi category schedule allow pullout any parameter in project no matter what of categories are selected by user.
For example:
1. I want create a Super multi category schedule for wall, beam, window and door.
2. First tab of UI, I select categories that I want to show: wall, beam, window and door.
3. Second tab of UI, I select parameters that I need from a list. The list will show all parameters from all category (built-in, user define,....). Parameters, for example, ID, category, width, height, function v.v...
4. Other functions like sorting, grouping are the same normal schedule.
5. When schedule show up, if any category has NOT a selected parameter in step 3, the cells of it will be grey out in the column of selected parameter.
6. This schedule allow to change value of parameter, even change the name of type. Dangerous but useful.
This super schedule is extremely useful for control and QA model. I know it because I am using an Addin that can create super schedule. I prefer a native super schedule from Autodesk because it's performance may be better than an Addin.
