structural parameter and other parameters
I need ( structural ) Parameter for walls & slabs to be type instead of instance because we always draw SE slabs & walls and forget to check this parameter
also, i think it will be great if we can change system parameters to be instance of type (or deleting from them) in our template file to match our need because @ my work we don't use them all and it consume some of the memory and processor
also when adding shared parameters to some thing like walls, i need to separate between basic walls and curtain wall
1 Comment
vincent_bergeron
Nice idea!
There are also a idea you might want to consider adding your vote to:
https://forums.autodesk.com/t5/revit-ideas/more-realistic-curtain-wall/idi-p/7531182
