Show only
Search instead for
Submitted byAnonymouson07-19-201808:23 AM
Status:
Accepted
Stretchable Tags
It is getting old having to create custom tags to control wrapping or width. In addition, linear stretchable tags could be useful in tagging things like wall ratings.
Yeah, while we're at it, it would also be nice to have the current width and height of text displayed in a tag available as a read-only parameters. This way we could drive all sorts of tag-related geometry. For example, we could create all manner of boxes around our tags that auto resize as the text changes.
Tags should have control points for the size of the text box in every instanse placed in project, at least the option of it. Like the texts annotations we control the size of the box. In tags we have only one size especified in the family. This could be controled in the instance of the tag family.
Much more important to me seems to be that text in all tags, would refer to only text types within the original file. Now if you want to use (have to use, that is, for multi-company-workers) one text style in one model, and another style in another project, now it requires duplicating all tags... this is (for me) an unacceptable way of dealing with this...
Currently Tags are fixed to the label width they are set to in a Tag Family. Can these have a flexi option to stretch the Tag family in terms of it's width within a project, exactly like what the annotation text box does. When the text box is stretched, the text automatically reconfigures to the stretched width. This should also be applied to Tags.
When a tag family is created and an element tagged to display its tagged parameter in one view, and the same tag family is used on another view, one would prefer to stretch the tag width to either increase or decrease it, but you cannot as the label width has been fixed in the creation of the tag family.
This forces one to either create additional tag families to suit or, create additional labels of various widths controlled with visibility parameters in the one tag family. This is unnecessary and a time consuming task, and furthermore causes "clutter".
This Flexi Tag function would apply to all Tag types, example:
Room Tags
Area Tags
Generic Tags
Multi-Category Tags, etc.
It shall make adjusting the width of a tag simple, efficient and a huge time saving exercise.
1000% agree. Came onto the forum to finally get around to posting this, and it is good to see others have already had the idea. Only downside is it appears to still only be gathering support after 8 years. The capability to have instance parameters in tags would be incredible. There are so many great use cases besides the obviously benefit of no longer having to have "Size 1, Size 2, Size 3, Size 4....." tag types in order to avoid the dreaded Multi-Line tags that can't be driven by formulas if we simply had the drag nodes like available in text.
In addition, it would be incredible to have instance visibility parameters to create popup text like "Optional" in front of the main text, or "Flush" vs "Dropped" Beams, or "SEE DETAIL", or Show Border. Obviously you can do that all with creating tons of Types (Tag Example-Size 1-Optional-Border, Tag Example-Size 2-Optional-Border, Tag Example-Size 3-Optional-Border, Tag Example-Size 1-Optional, Tag Example-Size 2-Optional, Tag Example-Size 3-Optional, etc) but the list grows exponentially fast as soon as you want to add any sort of creative style or tiny bit more technical detail that does not need to be a part of the model element to a tag.
Instance Based Tags would reduce the Types to "Tag". Which is MUCH more manageable.
For the time being, I have put formulas into the tags to read "Optional" if Optional is Check on the model, etc, but you still end up have tons of types because labels with no information leave an invisible "box" when printed (generally somewhat solved by a " " instead of "". You still have an invisible box that messes up your leader location now, so it makes more sense to have yet another tag type). So many workarounds to achieve smart, flexible tagging without having unmanageable amounts of tag types.
Also, the ability for adding ANY sort of additional parameters to keynote tags would be amazing. The keynoting concept is totally there, but it is too restricted (which I know it is meant to be) but it needs some quick additional text every now and then without having to go create an entirely new keynote for a one-off element.
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
