Start and End of Rebar and Rebar Sets
Currently a Rebar set has Start and End positions, but also the Rebar itself has a Start and End. After multiple copies, mirroring, rotating, apllying add-in(s) to divide in cut lengths or even split up sets you might loose control over what was the start and end of a Rebar (set), if it hasn't been change by the add-in(s) at all.
When you select a Rebar you can see the start position (where the shape handles are), but you cannot see the start or end of a Rebar itself, making Hooks at Start/End it most cases a gamble to choose from. When you lengthen a rebar you are in for the same gamble.
What if the Factory could make the shape handles more informative: green shape handles for start end red shape handles for red. This could benefit the lengthen of a rebar, hooks at start or end, but also think of the possibility for structural framing. And what it if we could switch the start and end point of a rebar and the start and end of a rebar set, this would make changing shape handles and layout of a rebar set more flexible.
7 Comments
SeanSpence
Being able to distinguish between all element (ie beams) start and end would be great!
Perhaps other colors or shapes for the handles, Red & Green tend to screw with people who have issues with color vision.
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
Status changed to: Archived
pieter.zeenaeme
@ThierryMonteyneSWECO
Too bad this idea didn't make it.
I just found it by a search.
You would certainly got my vote 🙂
Status changed to: Accepted
Stranger things have happened! 😊
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
The Factory
SeanSpence
I guess autodesk is looking at all these ideas. This one only had 4 votes and still got moved to the roadmap. Common sense feature enhancements are sorely needed! @kimberly_fuhrman-jones , thank you to you and your team for continuing to scour through these ideas. Gives me hope that someday soon, graphical column schedules and trusses can get added to the roadmap also.
We are pleased to say that this has been implemented in Revit 2026! Thank you for your contribution to improving Revit!
Help | Show Start and End of Bar | Autodesk
 -The Factory
