Stairs nosing material
It would be great if you could select material of stairs nosing. What you can do now is to paint it, however it takes time if it has many surfaces.
Also, I think I found a bug. You can't paint stairs nosing if Section box or Scope box is turned on. Also, you can't remove Paint from stairs if applied. You need to repaint it.
1 Comment
ahmedsherif-99
I have the same bug (can't paint stairs while using section box or scope box in Revit 2020)
Forma Design Contest
