I wish there could be a function were you can split a levels (similar as splitting a section) into several plus heights INSTEAD of create several independet levels, work with Plan regions in views or use the offset parameter to host objects at the correct height.
When working in plan views objects should be placed at the correct base constrain depended on which area of the view you working on.
