Sloped Walls
Sloped Walls
Please dont let us draw another mass.
31 Comments
harlan_brumm
Thanks for your submission and votes on this idea!  We are evaluating where this request falls into our roadmap and will provide an update when we have made a decision.
The Factory
minjie.wang
If prioritize these functions related to sloped wall:
- line based sloped wall creation
- curve based sloped wall creation
- sloped wall joining
- modify sloped wall profile
- window and door hosed on sloped wall
- sloped wall opening
- attach sloped wall to Roof/Floor
- sloped wall reveal and sweep
sasha.crotty
We've completed our review of this idea. After investigating the effort required to implement this request, we unable to add it to our roadmap at this time due to other priorities. However, we think this is a great idea so we will reconsider it as we made adjustments to our roadmap in the future. Thanks for the submission and keep voting!
The Factory
Kimtaurus
I'd also like a tool to input a variable wall thickness (a bit similar to floors and roofs with the Modify Shape Tool).
This would come in especially handy when dealing with existing situations, like for renovations.
magne.ganz
Also, please make sloped Walls able to Host Rebars. The "wall by face" of today is not able to host rebars. Thats a problem for us structrual engineers.
After having to switch from Revit to ArchiCAD for modeling purposes one of the first things I've had to do using Revit is model a sloped and angled wall.
I did a bit of Youtube searching and couldn't believe how much of a farce this process is, considering it's just a setting in ArchiCAD which has been there for the last 4 releases roughly, i thought the process would be relatively similar.
Come on Revit catch up! The amount of time required to create these walls is just ridiculous either through the massing process or via creating Revit families.
rana.hamed
Hi All,
We are in a great need for a slanted wall , just a generic slanted wall , its angle of slop to be under control , just a new wall type as the slanted columns,,,,,,
lionel.kai
@rana.hamed This idea is already listed for "future consideration":
https://forums.autodesk.com/t5/revit-ideas/sloped-walls/idi-p/6255757
and would also be solved by this idea:
https://forums.autodesk.com/t5/revit-ideas/loadable-wall/idi-p/6472196
lionel.kai
Being able to control the slopes of both faces of the wall independently (for CRM retaining walls) - would also be usable as a simple slanted wall.
would also be solved by:
https://forums.autodesk.com/t5/revit-ideas/wall-sweeps-reveals-that-follow-the-wall-top-bottom-edge-...
or
OndrejVinar
Without sloping walls (define angle of both faces) and without variable wall thickness, Revit is absolutely unusable for monuments restoration. Its fine to make complex wall using Mass Modelling. But make it behave like a regular wall (hosting openings, rebars and other elements, etc.).
OndrejVinar
Very recently (10 yrs ago) I´ve used ArchLine. Check it for your inspiration. Its wall-forming abilities were excellent.
rana.hamed
I am already have created the sloped wall (slopping from one face) by using in place family , but I have a lot issues as updating the profile (for design modification) , inserting openings as windows and doors which act with a very weird behavior and could not be hosted all the time.
Rana Hamed
Architect - Bim Specialist
Smart Village, Cairo-Alexandria Desert Road
Street 26, Building 10
P.O. Box: 129, Giza 12577, Egypt
Tel: +202 3531 8000
Fax: +202 3537 1223
dar.com
[cid:image001.png@01D26B25.EC7CF5A0]
Please consider the environment before printing this document
ArchiCAD has had this ability in at least the last 4 iterations of it, so it is possible to add as a function in Revit, and it works brilliantly.
m.steffannoe
And make it possible to use linear sweeps around corners with them.
Of course geometrical correct to get height points for each top and bottom point we need. This is possible when defining more than one path to sweep along.
Sloped or Slanted Walls. The ability to have a property of a wall that tilts it per a parameter.
m.steffannoe
@Anonymous
Good idea. For each side of the wall a separate parameter. But will this be correctly exported via IFC? These parameters aren't in IFC, don't they?
Or the export has to interpret these parameter and calculate a correct volumetric body.
mileta_pejovic
Almost 2 years later is there any progress with implementing this feature?
Would be nice to finally add this feature in the Revit roadmap.
We definitely understand it's a big deal for the developing team, but it's even bigger deal for Revit common users. Thanks!
hve-architecten
Its very cumbersome to create slanted walls. In revit lt its just impossible.
Would be great to see if you could create slanted walls just like slanted columns
bjoern_teutriene
This improvement would be very important for German Revit users. In the Revit Wishlist 2017 in Germany it ranked #13 out of 52 wishes. You can find more information on https://www.rug-dach.de/
lionel.kai
@bjoern_teutriene Could you post a link to the wishlist itself (just curious)? The www.wishlist.rug-dach.de link just goes to the voting page (which is done) and I don't see anywhere to get the results.
