For some reason, Autodesk decided to change the way for installing updates with the 2022 software. One can no longer silently install the downloaded update .exe file. It has to be extracted and then the various .msi and .msp files have to be installed one by one. Had a small discussion about this with one of the support members of Autodesk. Turns out it's probably due to the new installer - ODIS, that came up with versions 2022 (in some software it was released earlier).
The work-around is a bit ‘how you do it’. But it certainly adds to the time needed (and complexity) to get 2022-software up-to-date. That’s weird, considering the pre-2022 updates would install OOTB. So Autodesk, please redesign the 'update experience'?
