± Sign for 0.00 Elevation
For positive elevation there is the "+" sign, for negative the "-" sign, could we have also "±" sign for 0 elevation?
5 Comments
samuelsanf
Zero should not have sign.
± Means more or less, or a mathematical expresion to replace the operation for plus or minus signs. But not that the number is positive and negative a the same time.
Vladimir_Petko
"±" sign is a common use in many markets. Here an example from the swiss norm SIA 400.
@samuelsanf : Plus-minus is an architectural convention, not a number. It marks the limit between the infrastructure and the superstructure of a building.
Vladimir_Petko
@victor_vijeuKD42L the Video you posted is a good trick but it doesn't help with the spot elevation.
