Shortcut for 'pick a plane as workplane'
When modeling, we use the 'pick a plane as workplane' command a lot. Right now it takes 3 clicks to activate that command (Set > Pick a plane > OK). Can we have shortcut to activate this command directly?
7 Comments
I have the keyboard number 8 set as a shortcut for set plane. Hit p next checks the pick option , then enter for ok. That is 3 keys and my cursor is ready to select the working plane. A lot quicker than navigating menus and dialogue boxes.
But I agree, adding a direct keyboard shortcut to select working plane is a long standing Wishlist item.
annt_mth
Strange. I cannot vote this idea. Something wrong.
Radish_G
Hi Pieter, I am using the command called "Orient to A Plane" to set the current plane to any planer surface. Search it in the Keyboard shortcuts Dialog box and set the shortcut key's
@santhorati Thanks but that's not what I'm after. I want to activate the workplane with 1 shortcut, not change my view orientation. Right now I need at least 4 clicks to set my workplane by face: 1- open the dialog (by clicking on the button or using shortcut) 2- selecting "pick a plane" 3- clicking ok 4- click on a plane We do this enough that reducing the steps would be really welcome. For example: - using shortcut - click on a plane
nreyesidl
I want to activate the work plane with 1 shortcut too.
or let us have more freedom to create the "path" in custom short key.
Wish is wish.........software improvement is fulfill human/market's wishes.........
The success of AutoCAD, because we can use lisp do do almost anything. We spend money buy a software as a tester not even a user.
And the programmer/developer not even listen what we need always.........
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our Revit roadmap. Thanks for the suggestion!
The Factory
We are pleased to say that this has been implemented in Revit 2023! Thank you for your contribution to improving Revit!
-The Factory
