Make it possible to add sheets to a sheetset via the properties palette (make a sheetset parameter)
This would give me the possibility to select sheets directly form the projekt browser,
add them to a new or existing sheet set.
and then from the print/export dialog quickly print/export quickly make some outputs.
And mabye fix it so that blank spaces in DWFx files doesnt get deleted.
And make it possible to avoid prefixes. so sheet number and sheet name is right.
