Shared Parameter ID’s
Do Shared parameters need ID’s?
Without ID’s, schedules with double parameters with the same parameter name wouldn’t exist in a project.
Often, I see schedules with double parameters when loading external content.
Not everybody is aware of the ID’s that are connected to the name of the parameter! This is a major problem.
In example below next to the Revit built in parameter (Fire Rating) 2 shared parameters of FireRating are visible.firerating3.JPG
FireRating as in default Autodesk IFC Shared Parameter file has an ID.
Creating FireRating in your own parameter file will make a different ID.
Loading this parameter into a new family will create a second field in the schedule of a project.
When external content was created with a different parameter ID, a 3th field will appear in the schedule.
Also, some add-ins automated create parameters if not existing in a project and this will cause the same issues.
Copy/paste the ID from “IFC Shared Parameter.txt” to own shared parameter file is a solution.
All available content should be checked and reconnected with the correct parameter.
But not for all parameters a predefined parameter exists or an existing parameter files is available.
