Selective equality dimension
The EQuality function in dimensions ensures equal distances amongst all witness lines between the outermost limits. However it would be helpful to be able to select which dimensions within the total limit are to be equal.
For instance this could be used to ensure equal distances at the sides of an element that does not have a center reference (or where not the geometric center is wanted as the dimensioning factor).
In effect it would almost be like a temporary global dimensions that is assigned to the measuresments that are to be equal.
2 Comments
It is so useful to have Non-continuous equal for Dimension. now it takes time to do this.
Instead of this solution, it should be semi-automatic.
Mark_Engwirda
Yep, this regular enough circumstance
