segment section lines which are not perpendicular
I received a request from our Enterprise Priority customer recently, they want to create a section line for the stair below:
Currently, we can create segment sections lines, but they must be perpendicular or parallel to each other. Their workaround is to create two separate sections and combine them to make it look like one section.
If we can choose a random line and create the section line accordingly, that would be great. For example, create a section for a curved stair and parallel to the curve center as shown in the image below:
Thanks!
43 Comments
JensDeSmedt
Indeed, it would be great if we can create a bended section to check free head space of complex stairs and slopes.
This function will also be very useful to create unfolded section or elevation views, which are needed to make complex (bended) facades constructable.
pieter7
Here are some similar or duplicate ideas to this post:
https://forums.autodesk.com/t5/revit-ideas/curved-section/idi-p/6467058
https://forums.autodesk.com/t5/revit-ideas/section-or-elevation-for-curved-objects/idi-p/6707921
https://forums.autodesk.com/t5/revit-ideas/flattened-curved-elevations/idi-p/6255768
All these topics (and this one) are all addressing the same problem and offering the same or very similar solutions. I think these topics should be merged together into one.
duanx
@pieter7
Do you know how to merge existing Ideas? I really think it is a good idea to collect all similar ideas and increase its impact!
pieter7
@duanx only moderators can merge ideas. You can reach them by using the report button you see under each post.
duanx
@pieter7 Thanks! I send email to Moderators!
pieter7
@duanx seems like the moderators merged all the ideas but this one. Perhaps you could ask them to merge this idea into this one: https://forums.autodesk.com/t5/revit-ideas/flattened-curved-elevations-sections/idi-p/6255768
With over 3700 ideas, it's important to combine very similar or identical request in order to make some impact.
It would be also highly desired to be able to create curved section lines especial in bridge design. On behalf of a customer from Germany let me publish this draft:
2017-12-14_1442.pngCreating Curved Cross Section, Bridge Engineering
ptodd
Hell Yeah! Who wouldn't want this. Come on Revit!
zefreestijl
Vote +1, please add the feature of Expanded Section for curvature or multi-angular Elements:]
mehtarajeshadesk
Its highly desired feature ,
hugh.lawrence
This would be highly beneficial to everyone that uses Revit! High priority item for me.
hliS658H
Yes, I wish there was a way to create an unfolded section/elevation.
m.marcotulli_RBTA
Community Visitor
PLEASE
imostafamagdy
yes
cathal.cocoman
Yes.
c.koelling
Observer
the tool would greatly improve revit
jasonFG89A
Community Visitor
This feature is very much needed.
jekb
Community Visitor
YES. I need this to get control of the hights, and placment of buildings along a sloped curved road.
kevinguinan1
Community Visitor
segment section lines which are not perpendicular are badly needed
mgigliotti
I work in entertainment industry where geometry can get quite odd and sections like this are often needed.  This would be VERY useful.
