Section Cut Markers - Multiple segment lines. (ERP-6)
When placing section cuts on a plan, we have the option of "breaking" the line and adjust the segment end positions of the line breaks.  But you can only put in ONE line break.   Why only ONE line break?   There are times the drawing has so much information on it, we need to break up the section lines into multiples segments to go around texts and other objects on the plan view, and still be able to show there's a section going through.   Right now the work around is to make one large break, and then manually draw in smaller, matching "detail lines" to create the segments in between.    And you also can't " lock these lines to the section mark, so when moving or erasing these section marks later, you have to remember to move/erase any additional detail line segments drawn in.    ----  This is basic drafting stuff, so I don't understand why multiple line breaks wasn't considered in the first place.   Please make this change, as it should be real simple to do,  - so I hope we don't have to wait 10 years for it.
