Section box parameters top and bottom
Section boxes have a top and bottom.  It'd be great to have that tied to a level so that 3D views can be setup with precision.  And exporting Level slices to Navisworks is a lot easier.
4 Comments
jkidder
It would be very useful if these were in the properties window! Especially since its so hard o locate the arrows, and at certain angles top and bottom ones are grabbed by mistake.
This can be done by clicking right on the viewcube and select orient to ...
germanperales
The same can be said about reference boxes.
jkidder
@Anonymous That's a tolerable work around for level slices, and for views you set up once for a sheet, but for general use it's annoying.  I'd like to be able to select the section box and, without changing my view, adjust what I'm seeing.  For example, I might start with a view that's showing the first floor, and want to see the entire building.  Ideally I could select the selection box and change the range to 40'.  Instead I have to twist the view to find the arrow, then eyeball how much to drag it (usually taking 2-4 times) to see what I want, then twist the view back to approximately where I had it.
