SCOPE BOXES [Control visibility & size via API]
We need API for Scope Boxes to be able to control visibility and size.
The workflow today is way to manual. With the API for Scope Boxes we could make tools that would make the control of sizes and visibility way more easy to handle.
14 Comments
Please allow us to create Scope Boxes by the api
Tags (2)
This will be great. We need that to improve and automatizes the drawings production.
Any updates on this?
ProtoTechSolutions
Hello Support,
It would be very interesting feature to allow user to change geometry of scopebox via API. Allow to change the geometry obtained from get_Geometry(Options) method?
Ideally user should be allowed to set the X,Y extents of the scope box by selection. Allow to snap the edges of selected scope boxes to selected family in GUI as well as via APIs.
Mahesh
Agreed. This tool is pretty weak without finer control.
jstirlingJE9ZH
Updates?
chris_kim
three years after still no update ?
ahmadtN4DWZ
It would be great if the Scope Box class is made more accessible through the API. Currently, it seems like there is no way to modify existing scope boxes easily if at all via the Revit API. For example, It is not possible to access/modify existing Scope Box parameters such as Views Visible directly from the API. I attempted to do this by collecting all Scope Boxes in the document using the BuiltInCategory VOLUME_OF_INTEREST and then tried to extract the parameter value of the BuiltInParameter VOLUME_OF_INTEREST_VIEWS_VISIBLE. However, it seems to be non-UserModifiable and it kept returning nothing. I tried snooping the Scope Box parameters using Revit LookUp and it seems like this parameter is not user modifiable.
Tags (1)
isotoPEAJ9
still no scope boxes functionality in Revit API?
dmaral
Any news on that? It would be great to adjust their geometry if we'd like to set the box precisely..
dezindzer
Also it would be great if we could create them using the API
ksmithBMBHQ
The more I mess around with Dynamo, the more I keep running into this brick wall with Scope boxes. If you could set the location of scope boxes through the API, there are so many possibilities for parametricizing workflows and packing loads of function into a project template file. Scope boxes are almost the smartest feature in Revit, and it's wild to me that they stop just short of being incredible
rcrdzmmrmnn
Scope boxes aren't fully exposed in the API. They don’t even have their own class; they belong to the Element class. They also don’t have parameters like width and length. So, please create a subclass like ScopeBox  and a constructor that takes a BoundingBoxXYZ object as it's argument. That would be great.
VIgbinobaro6BVGR
Community Visitor
Scope boxes have been a long-standing limitation in the Revit API. After all these years and despite numerous votes, they still don’t have a dedicated class, they’re just generic Element instances with minimal accessible data. I can’t even get basic properties like width and length, which severely restricts any meaningful automation or manipulation. Can we please get a proper ScopeBox class exposed in the API?
