Scheduling Titleblocks
It would be nice for the schedule tool to be able to accommodate scheduling Titleblocks.
A titleblock schedule would allow the user to quickly and efficiently change bulk sets of titleblocks within the project to a different titleblock family. Or to easily review Titleblocks to verify their sheet sizes.
3 Comments
germanperales
This is a must for projects with sheets on different sizes.
lionel.kai
It would be good to also schedule the origin (position) of the Titleblocks. The USCOE project template (for example) has placeholder sheets with Titleblocks moved from the origin. This drove me crazy when trying to copy-paste graphic scales, north arrows, detail grids, etc. from one sheet to another!
It would be good to also be able to verify that there's only one Titleblock on each Sheet.
EDIT: and a somewhat-related idea: Fix OOTB Titleblock origins (templates and families)
lionel.kai
A related add-in: pyRevit > [Drawing Set] > Sheets > Select TitleBlocks on Sheets It will select the Titleblocks on the Sheets that you select (which is great if you need to change the Titleblocks on a range of sheets), but doesn't tell you which TB each sheet has (unless all the ones you select are the same). To see a list of all the Titleblocks, there's a dynamo script here: https://forums.autodesk.com/t5/revit-architecture-forum/list-of-titleblocks-used-on-sheets/td-p/9967...
Forma Design Contest
