Schedules - Add Column Size to Schedule Properties > Formatting
Would be nice to be able to see and modify schedule's column widths within the Schedules Properties. The Formatting tab would be my recommendation. Allow for multi-selection of parameters too. Especially handy for hidden columns. As it is now you have to first unhide the column, select the column, change the width, then re-hide it.
1 Comment
arq_42
Additionally, if you change the columns, create a view template, and apply it to other schedules, they inherit the column widths, and the "Resize" button becomes grayed out, preventing any modifications.
If you disable any of the tabs (Field, Filter, etc.) in the template, you can modify these options in each view, but the "Resize" button remains grayed out as long as a view template is applied.
This means that if you already have a view template applied and want to modify the column widths in all schedules, you must remove the template, change the width, create a new template, and reapply it to all schedules.
And everything would be solved with that editable field in "Formatting"
