Rotate Legend Components
I think you should be able to rotate legend components of any family. That is all.
24 Comments
jrfrost
We should have the ability to rotate a Legend Component.
Tags (1)
And I would add that we should be able to define the properties of the component in the same was as with the family it's based on.
Clarke_Symetri
Is there any way we can combine all "legends" ideas into one? Off the top of my head, these are the improvements I'd like to see with legends:
tag legend components
override the visibility/graphics of legend components, by element and category
Linework override
Insert legends into other projects
Agree to all of these comments!!! come on RVT 2018!!!! Autodesk you can do this!
Not only the Legend Component cannot be rotated, the Legend itself placed in the Sheet also has this limitation.
Simple request for a non critical problem, but still annoying.
guillermo4JEUL
A Basic function very needed!
ben.studiomod
come on RVT 2019!!!! Autodesk you can do this!
ben.studiomod
come on RVT 2020!!!! Autodesk you can do this!
ben.studiomod
This must be a very difficult thing to program...
come on RVT 2021!!!! Autodesk you can do this!
It has been very long time that this problem was raise in the forums.
It will be very useful for the user to be able to rotate the legend component of family and to be force to create 2d element or use other way that will make creating drawing legends more time consuming.
g.maksymowski
I would like to have that feature in some RVT.. 😉
zwebber24
Not being able to rotate legend components is extremely cumbersome. At the very least the native Revit families should appear correctly when dragged onto a legend.
J'ai eu le même besoin, merci de prévoir une rotation des composants de légende pour REVIT 2022.
nanna
..rotate AND mirroring would be very helpfull!
randerson
I agree with being able to rotate any legend component of any family, this should have been enabled along time ago.
we cant keep on edit our families to suit, or have to create or load a 2d symbol for that.
safwat_elsaket_
Just passed by this page in 2023
still no response from Autodesk
ViviNyehuusAndersen
Components can´t be rotated!! This is not very flexible, and again we are forced to have 2D symbols inside legends, and they are not updating with families used in the project.
Sorry if I've posted this before but Autodesk isn't doing enough
l.tejeda
We are in Revit 2025 and this functionality is still missing. . . is there any hope it will ever be available?
dol_joao
Community Visitor
Bonjour,
La rotation ne fonctionne pas sur les composants de légende.
Je suis en train de faire une légende de composants d'éclairage et ma réglette LED reste à la verticale, impossible de la tourner. C'est dommage, un tel blocage est vraiment rédhibitoire pour une utilisation de carte professionnelle et, vu le prix de ce logiciel et sa complexité, bien que l'outil soit très puissant, ce genre de galère l'empêche de prendre la place qui lui est due dans les BE Electrique.
Cdlt.
j_perkis
Come on Autodesk. This is not a difficult ask.
