Rotate after placing
i have an idea idk if its has been submitted before or not,
rotating components after placing will be helpful for placing tress, foliage, and people in the model. to give it the alive feeling instated of having to rotate each one.
+ in the Randomize placing under the generative design also need to have a rotate families.
thank you
2 Comments
J.Dirkse
And using the rotate-command (RO) after placing? (the R3-shortcut doesn't work in this situation)
Then you can rotate the placed instance and directly place another one.
Or do you mean something different?
SalehBHWZH
Observer
I can check the rotate after placing but that will required me to rotate it manually after placing, what i mean is for example i want to place punch of trees manually i want when i place one Revit automatically rotate the tree random angle for the next placement without me having to give it an angle of rotation after the placement
in image no 1 i have rotate placement on but when i place it if will ask me to rotate it manually(image 2),
i want an option to random rotate after placing
