Revit Type Naming from Parameters – Native Feature Request
One of the biggest sources of error in BIM is manual type naming. A simple yet powerful improvement would be a native Revit feature that allows users to auto-generate Type Names by concatenating selected parameters.
For example, a window type name could be built from:
[Width] - [Height] - [Frame Material] → 1200 - 1500 - Alum
This would:
  • Reduce manual errors
  • Enforce consistent naming
  • Make schedules and tags more reliable
Ideally, the Revit template could select 2–3 parameters in the Family Editor or Type Properties dialog, choose a separator, and have Revit build the name automatically.
BIM is only as good as the data we put in — and naming mistakes shouldn't compromise that.
Would love to hear if others see value in this or have workarounds without dynamo work arounds.
56 Comments
Hey is there a way we can get family type names with cancatenated values, this would be of help to get measures automatically in elements, lets say: Wood Table - Lengthxheight
Tags (1)
PieterL_TM
2024 now, why do we still not have this 😞
I suggest to Autodesk to look at 'family'-creation in Tekla Structures. They have this function and it works like a charm.
PieterL_TM
2024 now, hello?
437 votes, and I don't feel like it's such a difficult thing to achieve, please Autodesk...
maxim_jonckheere
Community Visitor
Update?
maxim_jonckheere
Community Visitor
Update?
王欣阳
是否是象这样的名称规则,用参数来定义族类型的名称?
其实根本的问题之一还在于revit缺乏“楼层”的概念,所以造成族类型的名称需要用很长而冗余的命名方式。 这是软件的痛点,希望软件公司能重视用户的呼声,广大的中国网友想帮助改善软件,但是需要你们能放下高高在上的姿态,倾听一线用户的声音!
mhiserZFHXS
Yes please.
Families and parameters could use a real overhaul to make the info in them more functional. Autodesk needs to just lump together all of the many ideas posted here for families/parameters and build the type editor from scratch.
MiWolff
I found it somewhat misleading that this 'new' idea already got more than 400 votes. Reading through the comments that date from before this idea's inception, it may be good idea to note the original idea's date when merging ideas. Something like 'Merged with an idea from 20170402.'. Looking at the new idea's date this may also be a cruel april's fool joke.
samuelsanf
I like the idea, but I would prefer if the naming with parameter could be also editing in the project file through "Edit Type" window, using tags as "@Height", "@Thickness", "@Material", etc.
This could help for unifying libraries with different units in names (imperial, metric or metric with naming in mm to make al naming in meters with two decimals).
But also there would be components were the user wants the units in specific format (like Windows dimensions "@Width" and "@Height" as default in meters per Project Units, but "Glass Thickness" in millimeters, maybe like "@Glass_Thickness%mm".
I always says that Revit should also let the user for label/display (project) parameters and views (maybe with different character for views like #) into text notes and tags (maybe element parameters for tagged object or text notes with leader associated to an element). :
joejaludi
Love this, would be incredibly useful.
harry.kempUF58Q
Often, when creating families, the type names include dimensions such as 200mm, 250mm, etc. If we could use a formula to generate type names automatically, it would streamline the process and help maintain a consistent naming convention across the office.
TypeName = "DoorWidth" & Width & "Height" & Height & Material & FireRating
This would produce names like: DoorWidth1010Height2110OakFD30
By setting up these formulas in advance, we can standardise naming conventions and reduce manual input errors when creating new types.
Mike.FORM
Susana_Duarte_LMSI
Don't forget we would need to indicate the units for each of those mesurement fields, so they don't change if the project units change.
esatis
Guys, we made this idea into reality, you can now get this free addin https://www.rename-pro.com that does exactly what you have been asking for years and even more. Enjoy!
WEIxxulc
awasyliw
I'm normally very wary of the "use dynamo" response to a request, and I do note you excluded dynamo when asking for solutions. However I would just point out this partiular tool is very easy to create in dynamo and I'm not really sure why you would reject it outright for something like this.
That said (and I await the deluge of snarky replies because of it) I do think the fact that people often use dynamo for this shows how beneficial people gfind it. I think Revit's BIM tools would greatly benefit from a suite of renaming and data completion tools such as suggested by the OP.
You get my vote, but I hope if picked up this is taken as a wider "how can we give you more tools to efficiently complete BIM data population".
