Can you add "Dimension.Segments" to the MCP tool list.
Right now the MCP can only read the total length of a multi segment dimension string. This is useless if I want to run an audit of dimensions to pull out segments that go below a 1/4" tolerance for example.
@RLY_15 mentioned this is possible with Dynamo or the API environment, but I don't have much coding knowledge to use those.
