A feature that would significantly improve workflow efficiency in Autodesk Revit would be the ability to transfer or reuse linked model and DWG visibility overrides between view templates.
At the moment, setting up linked model and linked DWG overrides can be repetitive and time-consuming. A more flexible workflow could be introduced through two additions:
This would provide a much faster and more consistent way to standardize linked file graphics across projects while still maintaining template flexibility. It would also reduce setup time, improve QA consistency, and minimise manual visibility coordination between views and disciplines.
